Ultimate Robot Kit V2.0
SKU:
90040
Weight:
4.18 KGS
UPC:
193122000086
EAN:
6928819504424
  • Ultimate Robot Kit V2.0
Description
 What is Ultimate Robot Kit ?
Ultimate 2.0 is our most advanced 10-in-1 educational robot kit that has 550+ mechanical parts and electronic modules that allows you to build 10+ models from one set. Ultimate 2.0 also has superb motor control and great compatibility with Arduino & Raspberry Pi so that you can build a range of complex designs.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Features
 10 in 1
With 550+ mechanical parts and electronic modules,you can build 10+ models from one set.
 Mainboard MegaPi with powerful Drive capability
MegaPi Mainboard, capable of simultaneously driving up to 10 servos, 8 DC motors or 4 stepper motors, has 4 extension interfaces which provides access to different types of sensors.
 Supports multiple programming languages
Block-based programming software enables you to program the Ultimate 2.0 by dragging and dropping function blocks. It also supports Arduino IDE and Raspberry Pi.
Wireless Control
Use your iPhone or Android smart phone or tablet to program Ultimate to move wirelessly.
Software
 mBlock:
One-stop coding platform tailored to coding education, trusted by 15 million educators, and learners
 Makeblock (Mobile):
A standard app for controlling and programming Makeblock robots.
 mBlock 3(PC):
A block-based programming software compatible with Arduino.
Specifications
Version
Packing Method
Box Packing
Product Information
G.W:2.47kg, DIM (L.D.H):41*20*24.5 cm
Package Information
G.W:4.18kg, DIM (L.D.H):51*31*15 cm
Carton Information
1pcs/ctn, G.W:4.18kg, DIM (L.D.H):53*17*34 cm
Part list
4×Beam0824-016
2×Beam0808-024
5×Beam0824-032
3×Beam0824-064
4×Beam0412-076
4×Beam0412-092
2×Beam0824-128
4×Beam0412-140
1×Slide Beam0824-176
2×Slide Beam0824-192
6×Beam0412-188
2×Beam0412-220
1×Plate 7×9-B
2×Plate 3×6
2×Plate0324-056
3×Plate0324-088
4×Bracket 3×3
2×Bracket P3_P3
4×Stiffener1616-08-M4
6×Shaft Connector 4mm
1×Plane Bearing Turntable D34×24mm
10× Countersunk Screw M2.5*6
60× Nut M4
12× Nylon Lock Nut M4
16× Headless Set Screw M3×5
10× Headless Set Screw M3×8
6× Countersunk Screw M3×8
6× Countersunk Screw M3×10
60 × Screw M4×8
50× Screw M4×14
10× Screw M4×16
12× Screw M4×22
8× Screw M4×30
12× Shaft Collar 4mm
12× Flange Copper Sleeve 4×8×4mm
4× Brass Stud M4×16
4 × Brass Stud M2.5×19
5 × Brass bolt M2.5×12
2× 4mm D shaft 50mm
1× 4mm D shaft 160mm
2× Shaft D4×88mm
6× Threaded Shaft 4×39m
3×Plastic Gear 8T
2×Plastic Gear 56T
6×Plastic Timing Pulley 90T
2×Plastic Gear 72T
20× Plastic Ring 4×7×2
20× Plastic Ring 4×7×3
6× Plastic Ring 4×7×10
20× Plastic Rivet 4060
20× Plastic Rivet 4100
20× Plastic Rivet 4120
10× Rubber Bank
10× Nylon Cable Tie 1.9×100
4×Rubber Blanket
4×Tire 90T B
2×Track 70×139mm
1×360°Mobile Phone Bracket
1× Wrench 5mm&7mm
1× Small Fourway Socket Wrench
1× HEX Key 1.5mm
1× Cross&2.5mm HEX Screwdriver
1× HEX Key 1.5mm
1 × Hardware Pack
1× MegaPi_MegaPi V1.0
1× Megapi Shield for RJ25 V1.0
1× Bluetooth Module V1.1
1× Me Line Follower V2.2
1× Me Shutter V1.0
1 × Me 3-Axis Accelerometer and Gyro Sensor V1.2
1× Me Ultrasonic Sensor
1× Me Adapter
4× Megapi Encoder/DC Motor Driver
2×MegaPi Acrylic Bracket
1× Makeblock Robot Gripper
1× 25mm DC Encoder Motor 9V/86RPM
2× 25mm DC Encoder Motor 9V/185RPM
3× 25mm DC Encoder Motor Cable
3×25mm DC Motor Bracket
2×25mm Motor Bracket-72T
1× USB Cable B-1.3m
1× 6P6C RJ25 Cable-35cm
2× 6P6C RJ25 Cable-20cm
1 × PH2.0-2P to Stripped-End Cable - 35cm,22AWG (Pair)
1×Battery Holder 6AA
1×Quick Release Plate
Resources
• User Guide
Videos
Images
Introduction
View AllClose
