Rotary Roller Engraving Module
SKU:
P5010098
Weight:
1.08 KGS
  • Rotary Roller Engraving Module
Description
• What is Rotary Engraving Module?
Working in combination with Laserbox, the rotary engraving module allows you to engrave cylindrical materials of diameters 3mm to 70 mm. It can be used to process all kinds of cylindrical materials based on your own design.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Note
Rotary Roller Engraving Module need to be used with Laserbox Rotary machine
Specifications
Package Dimension
(Height/Width/Length)
25*16.8*7.1cm
Product Dimension
20.4*13.7cm
Packing Method
Box Packing
Gross Weight
1.08kg
Part list
1 x 2.5mm L Hex Key
1 x Rotary Engraving Module
2 x M3*8 Hex Screw
1 x Terminal Cable
View AllClose
