Robot Arm Add-on Pack for Starter Robot Kit-Blue
SKU:
98000
Weight:
0.81 KGS
UPC:
193122005425
EAN:
6928819500198
UPC:
193122005425
  • Robot Arm Add-on Pack for Starter Robot Kit-Blue
Description
 What is Robot Arm Add-on Pack?
Robot Arm Add-on Pack serves to transform your Starter Robot Kit to a robotic-arm tank. It contains all parts you need for building a robotic arms, including DC Motor-37, Robot Gripper, beams, timing pulleys, and hardware.Composing of easy-to-assemble mechanical parts, color-labelled electronic modules, and a nimble gripper, controlled by IR remoter controller, this pack aims to bring more fun: pick up a bottle of water and get it delivered under your command.The gripper included in this pack is capable of opening an impressive 3" (67mm) wide. It enables you to grip items of various sizes according to your needs.The inner N20 screw motor of the gripper included in this pack will automatically stop running when the gripper is fully open or closed. This protects the screw motor from short-circuits and over-current, ensuring long-time use of the gripper.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Software
 Makeblock (Mobile):
A standard app for controlling and programming Makeblock robots.
 mBlock 3:
A block-based programming software compatible with Arduino.
Specifications
Version
Packing Method
Box Packing
Package Information
G.W:0.82kg, DIM (L.D.H):20*16*7 cm
Carton Information
20pcs/ctn, G.W:17.4kg, DIM (L.D.H):55*45*23 cm
Part list
1 x Beam 0824-64
1 x Beam 0824-80
3 x Beam 0824-96
3 x Beam 0808-168
3 x Plate 3x6
1 x DC Motor-37 Bracket B
1 x HEX Screwdriver 2.5mm
1 x Timing Pulley 90T
1 x Timing Belt 123T
3 x Linear Motion Shaft D4x88mm
8 x Shaft Collar 4mm
1 x Flange Bearing 4x8x3mm
16 x Socket Cap Screw M4x8
1 x HEX Allen Key 1.5mm
2 x Nylon lock Nut 4mm
4 x Countersunk Screw M3x8
12 x Headless Set Screw M3x5
6 x Plastic Ring 4x7x2mm
1 x Me Dual DC Motor Driver
2 x 6P6C RJ25 cable-20cm
1 x DC Motor-37 12V/50RPM
1 x Strong Robot Gripper
1 x Timing Pulley18T
14 x Socket Cap Screw M4x14
6 x Socket Cap Screw M4x22
8 x Nut M4
Resources
Education Resources:
View AllClose
