MakerSpace Kits2.0 Pneumatic Parts
SKU:
P1010105
Weight:
0.00 KGS
EAN:
6928819509924
Packing Method:
Box Packing
G.W:
3.61 Kg
  • MakerSpace Kits2.0 Pneumatic Parts
Product Description
Makeblock's Maker Education Solutions-Makerspace Kits, including a wide range of Makeblock's mechanical and electronic parts, are designed for schools to create a makerspace. The parts can be combined in different ways to meet different requirements, no matter it is for a maker event or a robotics competition.
MakerSpace Kits2.0-Pneumatic Parts includes pneumatic parts such as pressure regulator, solenoid valve and pneumatic cylinder.
Package Dimension
Height/Width/Length
outer     dimension:427x 312x75 mm
internal dimension:385x 283x70 mm
outer     dimension:16.81x12.28x2.95 inch
internal dimension:15.16x 11.14x2.76 inch
Part List  (Qty. x Part Name)
2 x Regulator GR20006F1
2 x Pressure Relief Valve
4 x Solenoid Valve 4V110M5FI
4 x Plug 3.96-2P
2 x Cylinder Ml10X60CA
2 x Cylinder MI10X150CA
4 x Bottle Cap
2 x φ8-φ6 Reducing Straight Connector
4 x Tube Connector PE6
2 x φ6 Cross Four-Way Connector PZ6
4 x Hand Control Valve 6-6
2 x Tube Connector PCFT6-02
4 x Tube Connector PC6-01
8 x Speed Valve PSL6M5A
30 x Tube Connector PC6M5
10 x Universal Copper Silencer
4 x φ6 Pneumatic Tube -Blue
2 x Sealing Tape
4 x Solenoid Valve Bracket(6061-T6)
4 x φ10 Cylinder Bracket(6061-T6)
4 x Rod End Joint M4
16 x Lock Nut M3
16 x Socket Cap Screw m3*25-Button Head
View AllClose
