Makeblock Power Expansion Board V1
SKU:
P3020001
Weight:
0.03 KGS
EAN:
6928819509474
Packing Method:
Box Packing
  • Makeblock Power Expansion Board V1
Description
Power Expansion Board contains an MCU with the ARM Cortex-M4 core, uses serial interfaces to communicate with NovaPi, and uses eight DC output ports and two brushless motor ports to control the powered devices such as DC motors, mechanical grabbers, electromagnetic valves, and brushless motors.
Features
Work with NovaPi
Can control Makeblock series powered devices such as 37 DC motors, electromagnetic valves, mechanical grabbers, and brushless motors
Can control common powered devices including DC motors, electromagnets, and electromagnetic valves
Eight DC output interfaces and two brushless motor interfaces
Embedded overload protection circuits to prevent exceptional conditions from damaging the shield
Require no extra external power supply
Specifications
Module dimensions
85 mm x 56 mm x 19.5 mm
Input voltage
6 V - 13 V
DC port voltage
12 V
Maximum DC port current
3A
Brushless motor port voltage
12 V
Maximum brushless motor port current
5A
Part list
1 x Power Expansion Board
View AllClose
