Laserbox Rotary
SKU:
P1030239/P1030240
Weight:
82.68 KGS
  • Laserbox Rotary
  • Laserbox Rotary
  • Laserbox Rotary
  • Laserbox Rotary
  • Laserbox Rotary
  • Laserbox Rotary
  • Laserbox Rotary
Description
• What is Laserbox Rotary?
Laserbox Rotary is a desktop smart laser cutter, designed for education and creation. With the high-definition ultra wide-angle lens and AI computer vision algorithms, Laserbox provides revolutionary functions, such as material recognition, visual operation, automatic parameter setting, and automatic focusing. As the first smart laser cutter that can cut and engrave materials based on hand drawing, Laserbox greatly reduces the difficulty in using lasers, allowing everyone to use lasers for creation.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Note
The Rotary Roller Engraving Module need to be purchased separately.
Features
Real-time camera preview
You can preview your design and visually position it on the material to be cut or engraved. The built-in 5MP ultra wide-angle camera lens allows you to view the working area in real time, ensuring accurate laser cutting or engraving.
AI auto focus
You can enable the auto focus function for previewing and material cognition to ensure high-precision laser cutting and engraving.
Pen drawing
You can draw whatever you want on paper or the material to be cut or engraved. Laserbox can recognize lines with the width of 3mm, red lines for cutting and black lines for engraving.
Software
 Laserbox Help in Edu:
Smart laser cutting and engraving software
 Laserbox Instruction:
Specifications
Net Weight(Laserbox Rotary
48 kg
Gross WeightLaserbox Rotary
60 kg
Package Dimension
(Height/Width/Length)
Laserbox Rotary:1040*640*440mm
Smoke Purifier Unit:633*404*336mm
Consumable materials:308*170*228mm*2
Product Dimension
Laserbox Rotary:958.1*528.1*268mm
Packing Weight
Laserbox Rotary+Smoke Purifier Unit+Consumable materials
82.68 kg
Packing Method
Box Packing
Part list
1 x Laserbox Rotary
2 x Smoke Exhaust Pipe
1 x User Manual
1 x Universal 3 Pronged Plug
3 x 2.5-inch Clamp
1 x USB Cable
56 x Basswood (Plywood)_3mm
45 x Cardboard_3.5mm
1 x Smoke Purifier Unit
1 x Purifier Filter Cartridge
1 x Aviation Connector
View AllClose
