Explorer Kits
SKU:
P1050015
Weight:
0.49 KGS
EAN:
6928819509221
Packing Method:
Box Packing
EU only
  • Explorer Kits
  • Explorer Kits
  • Explorer Kits
  • Explorer Kits
  • Explorer Kits
Description
 What is Explorer Kits ?
Explorer Kits is an upgraded kit of the makeblock star product mBot. It includes the original parts of the classic kit and further allows children to customize its LED dot-matrix screen.
As an educational and entertaining robot of makeblock, Explorer Kits is quite easy to get started with, which makes it a perfect tool that helps beginners with their STEAM learning (science,technology,engineering, art and maths). Children can build robots into different shapes and learn how to program with the graphical programming software provided by makeblock. In the process, children get hands-on experiences of how fascinating the world of mechanics, electronics,controlling systems and computer science can be.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Features
Explorer Kit has an LED Matrix which is not included in the standard version. This kit allows makers to build three different shapes of mBot.
The LED matrix display is versatile because children can program to customize the expressions, texts and weather reports on it.
Parts and components are standardized and user-friendly. Children can build their robots simply with a screwdriver.
The graphical programming is easy enough for children to create as they want and control the robots to play games, like obstacles avoidance and line-following.
Software
 Makeblock (Mobile):
A standard app for controlling and programming Makeblock robots.
 mBlock Blocky (Mobile):
Game-based programming software for STEAM education
 mBlock 5 (PC):
A powerful platform for coding designed for STEAM education
Specifications
Connection mode
Input
Bluetooth
Light sensor, button, IR receiver, ultrasonic sensor, line-following sensor
Output
Package Dimension
Buzzer, RGB LED, IR transmitter, two motors, ports
G.W:1171g, DIM(H.W.L):8.46*7.09*3.94 inch ; 215*180*100 mm
Product Dimension
N.W:485.4g, DIM (H.W.L):7.48*5.12*5.12 inch ; 190*130*130 mm
Remote Control
Yes
Part list
1 ×Mini Wheel
25 ×M4*8 Screw
8 ×M3 Nut
8 ×M4*25+6 Brass Stud
4 ×M2.2*9.5 Screw
3 ×RJ25 Cable 6P6C-20cm
2 ×Motor
2 ×Slick Tire
2 ×Plastic Timing Pulley 90T for Motor
1 × 4AA Battery Holder
1 ×Bluetooth Module
2 ×Motor Parts
1 ×Mainboard mCore
1 ×Ultrasonic Sensor
1 ×Me Line Follower
1 ×2.5mm Screwdriver
1 ×USB Cable
2 ×mCore Case
1 ×mBot chassis
1 ×White Acrylic array board
1 ×3*3*120° Bracket
1 ×HOOk&LOOP
1 x Line-following Track
6 ×M3*25 Screw
10 ×4*7*10 Plastic Spacer
4 ×M4*16+6 Brass Stud
8 ×R2064 Rivet
1 ×LED Matrix
4 ×M4 Nut
10 ×4*7*3 Plastic Spacer
4 ×M4*14 Screw
1 x Quick Start Guide
1 x Building Instructions
1 x IR remote control
Resources
• User Manuel
View AllClose
