AI & IoT Robot Education Kit
SKU:
P1050020
Weight:
3.36 KGS
EAN:
6928819510937
Out of Stock
  • AI & IoT Robot Education Kit
Description
• What is AI & IoT Robot Education Kit?
The AI & IoT Robot Education Kit includes an mBot robot and comes with 10+ electronic modules and accessories. The Smart Camera included is a camera that can learn, calculate and detect objects. The kit is designed to expose students to AI applications and enable them to use electronic modules to DIY fun AI projects.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Features
10+ electronic modules included are perfect for robotics, makers and coding related education;
Suitable as MakeX Starter supplies(Requires use with MakeX starter equipment kit);
Scratch & Arduino C, coming with mBlock's powerful AI services, enables AI teaching and applications(Baidu AI(China) and Google Cloud);
One package of educational supplies including mBot, electronic modules, smart camera and aluminium alloy structural parts, making it fit for different purposes.
Accompanying online teaching resources available, easing teachers' teaching load.
Software
 mBlock 5:
A powerful platform for coding designed for STEAM education
Specifications
Chips
ATmega328
Components included:
Smart Camera、Power、Audio Player、4 Button、LED Matrix、RGB-LED×2、RJ25 Adapter、Ultrasonic Sensor、Line Follower、9g Micro Servo Robot Pack×2、Bluetooth Dongle、Bluetooth Module、IR Controller (battery not included)、Lithium Battery、Micro SD Card、TT Motor×2、Orange EVA Ball ×3、Green EVA Ball×3、Metal Structural Parts、 Accessories Pack and more;
Power:3.7V DC Lithium battery 、Power(mBuild)
Wireless Communication:Bluetooth
Programming languages
Scratch, Python
Browser
macOS 10.10 or above/Win7 or above
App(only availabe on iPad): iOS 11 or above
Packing Method
Box Packing
Package Dimension
H/W/L
473×345×390mm
18.62×15.58×15.35inch
Product Dimension
H/W/L
427×312×75mm
16.81×12.28×2.95inch
Part list
1×Mainboard mCore
1×USB type B Cable
1×Micro USB Cable
6×RJ25 Cable-20cm
4×RJ25 Cable-35cm
1×RJ25-I2C Cable
2×mBuild 5V Universal Wire-20cm
4×Slide Beam0824-016
4×Slide Beam0824-032
1×Slide Beam0824-048
4×Slide Beam0824-080
4×Slide Beam0824-096
4×Slide Beam0824-112
4×Beam0412-044
4×Beam0412-076
4×Beam0412-092
6×Bracket3*3*120°
8×Braket 3*3
4×Plate 45°
2×Plate0324-088
2×Triangle Plate 6*8
2×Braket 3*6
2×Plate3*5*120°
2×Bracket U1
12×M4*25+6 Brass Stud
30×M4*30mm Screw
32×M4*22 Screw
50×M4*16 Screw
50×M4*14mm Screw
50×M4*8 Screw
6×M3*25 Cross Screw
4×M2.2*8.5 Self-Tapping Screw
50×M4 Nut
30×M4 Locknut
8×M3 Nut
30×R4100 Rivet
50×4*7*3 Washer
1×Wrench 5mm&7mm
1×Screwdriver
1×Bluetooth Dongle
1×Bluetooth Module
1×IR Controller (battery not included)
1×Audio Player+Micro SD Card
1×Power
1×Smart Camera
1×4 Button
1×LED Matrix
2×RGB LED
1×RJ25 Adapter
1×Ultrasonic Sensor
1×Line Follower
2×Plastic Timing Pulley 90T For Motor
2×Slick Tire
1×Mini Caster Wheel
3×Orange EVA Ball
3×Green EVA Ball
1×Lithium Battery
2×9g Micro Servo Robot Pack
2×TT Motor
1×Barcode Card+Barcode Sticker
1×Map A
1×Map B
1×mBot Chassis
1×Small Screw Box
View AllClose
