2020 MakeX Starter Smart Links Upgrade Pack for City Guardian
SKU:
P1100021
Weight:
0.66 KGS
EAN:
6928819510609
MakeX 2020 New
  • 2020 MakeX Starter Smart Links Upgrade Pack for City Guardian
Description
• What is 2020 MakeX Starter Smart Links Upgrade Pack for City Guardian?
This pack provides necessary upgrade parts for the contestants who have been in the 2019 MakeX Starter City Guardian program to complete the 2020 MakeX Starter Smart Links. It includes Me Micro Switch, new connector plates, brackets, shafts and other mechanical parts.
Specifications
Packing Method
Box Packing
Package Dimension
H/W/L
200*160*70 mm ; 7.9*6.3*2.8 inch
Gross Weight
6.59kg
Part list
2 x RJ25 Cabe
2 xBracket3*3*120°
2 xBracket3*3(blue)
1 x Bracket U1
2 x Plate 45°(blue)
2 x Triangle Plate 6*8(blue)
1 x Plate0324-072(blue)
1 x Plate0324-088(blue)
4 x Slide Beam0824-016(blue)
4 x Slide Beam0824-032(blue)
20 x Screw M4*14
1 x Mini Wheel
8 x Lock Nut M3
2 x Plate 3*5*120°(blue)
3 x Bracket 3*6(blue)
4 x Square Beam0808-136(blue)
4 x Beam0412-036(blue)
4 x Plate 7*9-B(blue)
2 x D Shaft 4*56mm
4 x Shaft Collar 4mm
2 x Shaft Connector 4mm
6 x Cuttable Linkage(blue)
20 x Flange Bearing 4*8*3mm
2 x Tyre 68.5*22mm
34 x Lock Nut M4
24 x Plastic Rivet R4060
30 x Plastic Rivet R4120
20 x Plastic Ring 4*7*3mm
20 x Screw Headless M3*5
1 x Micro Switch B
2 x HEX Allen Key 1.5mm
View AllClose
