2020 MakeX Starter Smart Links Add-on Pack
SKU:
P1100020
Weight:
1.49 KGS
EAN:
6928819510593
MakeX 2020 New
  • 2020 MakeX Starter Smart Links Add-on Pack
Description
• What is 2020 MakeX Starter Smart Links Add-on Pack?
This add-on pack provides contestants who have mBot with the upgrade parts necessary to complete the 2020 MakeX Starter Smart Links competition. It includes Bluetooth Remote, Lithium Battery (designed for use in robotics competitions), High-speed Motor (designed for use in robotics competitions), and structural parts.
Specifications
Packing Method
Box Packing
Package Dimension
H/W/L
290*223*100 mm ; 10.6*8.8*3.9 inch
Gross Weight
14.84kg
Part list
1 x LED Matrix
1 x RGB Line Follower
1 x 9g Micro Servo
1 x RJ25 Adapter
6 x RJ25 cable
2 x Geared Motor DC 6V/312RPM
4 xBracket3*3*120°
5 xBracket3*3(blue)
3 x Bracket U1
4 x Plate 45°(blue)
4 x Triangle Plate 6*8(blue)
3 x Plate0324-072(blue)
3 x Plate0324-088(blue)
4 x Beam0808-136(blue)
4 x Slide Beam0824-016(blue)
4 x Slide Beam0824-032(blue)
32 x Nut M4
50 x Screw M4*8
20 x Screw M4*14
6 x Plastic Spacer 4*7*10
4 x Brass Stud M4*16+6
1 x Wrench M5+M7
2 x HEX Allen Key 1.5mm
8 x Lock Nut M3
1 x Mini Wheel
4 x Plate 3*5*120°(blue)
4 x Beam0412-044(blue)
4 x Beam0412-060(blue)
1 x Bluetooth Controller
2 x Lithium Battery
1 x Bluetooth Dobgle
1 x Micro Switch B
2 x Tyre 68.5*22mm
3 x Bracket 3*6(blue)
4 x Square Beam0808-136(blue)
4 x Beam0412-036(blue)
4 x Plate 7*9-B(blue)
2 x D Shaft 4*56mm
4 x Shaft Collar 4mm
2 x Shaft Connector 4mm
6 x Cuttable Likage(blue)
20 x Flange Bearing 4*8*3mm
34 x Lock Nut M4
20 x Screw Headless M3*5
24 x Plastic Rivet R4060
30 x Plastic Rivet R4120
20 x Plastic Ring 4*7*3mm
View AllClose
