2020 MakeX Premier Ultimate Warrior Kit
SKU:
P1090026
Weight:
337.60 KGS
EAN:
6928819510647
MakeX 2020 New
  • 2020 MakeX Premier Ultimate Warrior Kit
Description
• What is 2020 MakeX Premier Ultimate Warrior Kit?
This is a complete competition kit designed for contestants competing in the 2020 MakeX Premier Ultimate Warrior. It includes the materials necessary to complete the competition, such as NovaPi, Me Power Management Module, Power Expansion Board, Dual RGB Color Sensor, Ranging Sensor, and Bluetooth Remote. Our new electronic parts can be programmed using Python and work perfectly with 36 Coreless Motor, Smart Servo, DC Motor-37, new lean beams and many other mechanical parts. The addition of Raspberry Pi Camera Solution can bring a great boost in visual tasks.
Note:The parts and accessories of our products (such as screwdrivers, screws, cards, etc.) will be iterated from time to time without affecting the use of the product. Therefore, there may be multiple versions of the parts, and the actual products may not be completely consistent with the promotional pictures or description pictures. This situation is an acceptable difference and does not belong to after-sales quality issues. The pictures are for reference only. Please refer to the actual product received for details.
Specifications
Packing Method
Box Packing
Package Dimension
H/W/L
543*370*225 mm*2; 290*223*100 mm*2
21.4*14.6*8.9 inch*2;11.4*8.8*3.9 inch*2
Gross Weight
337.6kg
Part list
4 x Slide Beam0824-016(Blue)
4 x Slide Beam0824-032(Blue)
4 x Slide Beam0824-048(Blue)
6 x Slide Beam0824-064(Blue)
6 x Slide Beam0824-080(Blue)
6 x Slide Beam0824-096(Blue)
4 x Slide Beam0824-112(Blue)
2 x Slide Beam0824-128(Blue)
6 x Slide Beam0824-144(Blue)
2 x Slide Beam0824-160(Blue)
2 x Slide Beam0824-176(Blue)
4 x Slide Beam0824-192(Blue)
2 x Slide Beam0824-224(Blue)
4 x Slide Beam0824-256(Blue)
5 x Slide Beam0824-320(Blue)
8 x Slide Beam0824-496(Blue)
2 x Slide Beam2424-072(Blue)
4 x Slide Beam2424-104(Blue)
4 x Slide Beam2424-136(Blue)
4 x Slide Beam2424-184(Blue)
4 x Slide Beam2424-248(Blue)
4 x Slide Beam2424-312(Blue)
4 x Slide Beam2424-424(Blue)
2 x Lean Beam-136
2 x Lean Beam-248
4 x Lean Beam-312
4 x Lean Beam-424
4 x Lean Beam-504
8 x Parallel Connector
10 x Lean Beam Adapter A
10 x Lean Beam Adapter B
40 x External Connector
16 x Cross Connector
8 x Extension Connector
16 x 90° Reinforce Connector
4 x 45° Connector A
4 x 45° Connector B
2 x Wrench M6
30 x Screw M6*12 Round Head
30 x Screw M6*16 Round Head
2 x Plate 45°
4 x Cuttable Linkage
2 x Plate I1
2 x Bracket 3*3*120°
10 x Screw M6*20 Round Head
80 x Nut M6
1 x Screwdriver 2mm
4 x Beam0412-076(Blue)
4 x Beam0412-092(Blue)
4 x Beam0412-108(Blue)
4 x Beam0412-124(Blue)
4 x Beam0412-140(Blue)
4 x Beam0412-156(Blue)
4 x Beam0412-172(Blue)
4 x Beam0412-188-L2-R1(Blue)
6 x Beam0412-188(Blue)
4 x Beam0412-204(Blue)
4 x Beam0412-220-L5(Blue)
4 x Beam0412-220(Blue)
4 x Beam0412-236(Blue)
8 x Square Beam0808-056(Blue)
8 x Square Beam0808-072(Blue)
8 x Square Beam0808-088(Blue)
8 x Square Beam0808-104(Blue)
4 x Square Beam0808-184(Blue)
6 x Beam0808-184(Blue)
6 x Beam0808-312(Blue)
8 x Brakcet 3*3(Blue)
6 x Bracket 3*6(Blue)
6 x Plate 3*6(Blue)
4 x Plate 45°(Blue)
10 x Plate 7*9-B(Blue)
4 x Plate0324-040(Blue)
4 x Plate0324-056(Blue)
4 x Plate0324-072(Blue)
4 x Plate0324-088(Blue)
8 x Plate0324-184(Blue)
6 x Plate3*5*120°(Blue)
6 x Bracket3*3*120°(Blue)
20 x Cuttable Linkage(Blue)
8 x Double Gear Rack
8 x 36 Encoder Motor-Brushless
1 x 2824ZWW-1Z-68-11.1 Brushless Motor
1 x 2824ZWW-1F-68-11.1 Brushless Motor
2 x Brushless Motor ESC
2 x Brushless Motor Bracket
2 x Friction Wheel D45*19.5
2 x Friction Wheel Ring D28*7
4 x 37mm DC Motor 12V/200RPM
4 x 37mm DC Motor 12V/50RPM
8 x 37mm Motor Bracket (Blue)
10 x PH2.0 Motor Cable
4 x Dual RGB Color Sensor
4 x Ranging Sensor
2 x Smart Servo MS-12A
2 x Mounting Bracket(Blue)
2 x Rudder Bracket(Blue)
2 x Virtual Axis
4 x Smart Motor Cable-20cm
10 x Smart Motor Cable-60cm
1 x XT60_XT30/DC One with three power cords
1 x Skyrc B6AC V2
1 x Bluetooth Controller
2 x Bluetooth Module
1 x Bluetooth Dongle
1 x Low Voltage Buzzer Alarm
1 x MegaPi Bracket
1 x Novapi Case
1 x Power Management Module Case
1 x Mainboard NovaPi
1 x PowerExpansionBoard
4 x 5V General Cable-20cm
8 x 5V General Cable-60cm
1 x USB Cable
100 x Track
100 x Track Axle
4 x Plastic Gear 8T
4 x Plastic Gear 56T
6 x Plastic Gear 72T
4 x Plastic Timing Pulley 18T
6 x Plastic Timing Pulley 62T
6 x Plastic Timing Pulley 90T
4 x Timing Belt-Open end(5m)
4 x Linear Motion Slide Unit 8mm
4 x Sliding Block A1
16 x Aluminum Sleeve 4*6*4
16 x Aluminum Sleeve 4*6*6
16 x Roller
8 x Nylon Pulley
6 x Belt Connector(Blue)
8 x Threaded Shaft 4*39
8 x D Shaft 4*56mm
6 x D Shaft 4*160mm
10 x Shaft D4*88mm
4 x Shaft D4*240mm
4 x Shaft D4*512mm
4 x Shaft D8*96mm-H
2 x Shaft D8*128mm-H
4 x Shaft D8*312mm-H
4 x Shaft D8*496mm-H
2 x D shaft 4*200mm
2 x D shaft 4*240mm
2 x D shaft 4*320mm
1 x Raspberry Pi Case
1 x Raspberry Pi
1 x Raspberry Pi Shield
4 x Shaft Clamping Hub 8mm
4 x Bearing 8*16*5mm
60 x Flange Bearing 4*8*3mm
8 x Flange Bearing 8*16*5mm
4 x Flexible Coupling 4*4mm
4 x Universal Joint 4*4mm
40 x Shaft Collar 4mm
8 x Shaft Collar 8mm
20 x Shaft Connector V3.0
20 x Shaft Connector 4mm
4 x 100mm Omni Wheel
4 x 100mm Omni Wheel Shaft Coupling
20 x Cuphed Screw M5*40
20 x Lock Nut M5
100 x Combination Screw M4*8
100 x Combination Screw M4*10
100 x Combination Screw M4*14
200 x Combination Screw M4*16
200 x Combination Screw M4*20
100 x Combination Screw M4*30
200 x Combination Screw M4*35
100 x Combination Screw M4*40
20 x Screw Headless M3*5
30 x Screw Headless M3*8
50 x Cross Recessed Countersunk Screw M3*8
100 x Lock Nut M3
300 x Nut M4
60 x Nut M3
100 x Lock Nut M4
100 x Plastic Rivet R4060(Black)
100 x Plastic Rivet R4100(White)
100 x Plastic Rivet R4120(White)
50 x Plastic Ring 4*7*3
20 x Plastic Ring 4*7*10
50 x Plastic Ring 4*7*2
2 x ScrewDriver 1.5mm
2 x ScrewDriver 3mm
1 x Wrench M5+M7
1 x HEX Allen Key 2.5mm
1 x Small Four-way socket wrench
2 x ScrewDriver 2.5mm
2 x HEX Allen Key 1.5mm
2 x 180 Smart Encoder Motor
4 x Gear 48T(Blue)
4 x Gear 80T(Blue)
4 x Gear 16T(Blue)
1 x FB4300HP-3S
Type a description for this product here...
View AllClose
